Copy Part
Hello
I am attempting to use the API to copy a part in the active station.
The following code works well, except when the part has many entities, it takes some time to complete.
Private Sub CopyPart()
Dim p As Part
Dim e As Entity
Dim cbpCommandBarPopup As RSEXT.CommandBarPopup
ActiveStation.UCS = ActiveStation
Set p = ActiveStation.Parts.Add
'catches the edit menu for the copy paste commands
Set cbpCommandBarPopup = RSE.CommandBars("Menu Bar").Controls("Edit")
'Copies the parts
ActiveStation.Selections.RemoveAll
For Each e In ActiveStation.Parts("part_to_copy").Entities()
ActiveStation.Selections.Add e
Next e
cbpCommandBarPopup.Controls("Copy").Execute
ActiveStation.Selections.Add p
cbpCommandBarPopup.Controls("Paste").Execute
End Sub
How does one just copy a part, without haveing to traverse through all of the entities?
I tried the following without success:
Dim p As Part
'Copy the part
ActiveStation.Selections.Add ActiveStation.Parts("part_to_copy")
End Sub
The key must be the line :ActiveStation.Selections.Add ActiveStation
But I have tried many different things without success.
I was successful in copying into an assembly by just the part reference, but how do you paste into the components part of the station?
Looking forward to your reply.
Tom
PACs Application Engineer
You don't.It's not possible from the API to directly select the 'components' in the browser.
But... If you want to do something really 'baaad' you could always use the "sendkeys" to go to the components.
So my recomendation would be to do it like you did first. Put it in an assembly and be happy.
John
Developer Center0 -
A bit more to the copy paste issue - I tried the same thing, using the CommandBarPopUp approach, and it worked fine when I ran the macro, but during run time, 'Operation is not allowed'.
Is there a way to copy/paste during run time? (ie for adding a new box to a conveyor by copying a reference box, rather than creating a new one from scratch)
Dean Thomas
ABB Support Engineer
Channel Partners Australia0 -
Hello Dean,
Here comes two code examples that work when you "Play" a simulation. I'm running on RobotStudio 3.0, what version do you have?
Sub CopyExample()
'When you copy you need to copy on child level and paste on parent level
Dim prtP1 As Part
Dim prtP2 As Part
Dim entE As Entity
Dim tfmT As New Transform
'We will now create two parts, one with a box and one that is empty
Set prtP1 = ActiveStation.Parts.Add
Set prtP2 = ActiveStation.Parts.Add
Set entE = prtP1.CreateSolidBox(tfmT, 0.5, 0.5, 0.5)
MsgBox "2 parts 1 entity"
'To be able to copy stuff we need to have them selected
ActiveStation.Selections.Add entE
MsgBox "The box is selected"
'Since copy doesn't exist on the object we need to call the menu
Application.RSE.CommandBars("Menu Bar").Controls("Edit").Controls("Copy").Execute
'Now we need to select the other part
ActiveStation.Selections.Add prtP2
MsgBox "2nd part selected"
'Finally we paste in the object, again from the menu
Application.RSE.CommandBars("Menu Bar").Controls("Edit").Controls("Paste").Execute
MsgBox "Now the second part should have a box copy"
End SubSub CopyExample2()
Dim prtP1 As Part
Dim prtP2 As Part
Dim entE As Entity
'Application.RSE.CommandBars("Menu Bar").Controls("Edit").Controls("Copy").Execute
Dim cbc As CommandBarControl
Set cbc = Application.RSE.CommandBars.FindControl(, 57634)
cbc.Execute
'Application.RSE.CommandBars("Menu Bar").Controls("Edit").Controls("Paste").Execute
Set cbc = Application.RSE.CommandBars.FindControl(, 57637)
cbc.Execute
End Sub'To get hold of the ID's above run the following.
Sub id()
Ulrika Mor?n38036,4532638889
MsgBox Application.RSE.CommandBars("Menu Bar").Controls("Edit").Controls("Paste").id
MsgBox Application.RSE.CommandBars("Menu Bar").Controls("Edit").Controls("Copy").id
End Sub0
- 40 AppStudio
