motion supervision option
Hi all,
Is there a way to check if motion supervision option is installed? Does it come with ever robot or is it a extra cost?
Thx
  • Hi,
    You can check the installed options via the FlexPendent, under the System Info topic on the main menu (right hand column)->system properties->Options.
    Basic motion supervision comes with every robot, but the option gives you more features.
    Hope this helps.
    Graeme
  • Graeme
    Thanks for the help
    It looks like it is not installed.
    Maybe this is why I can't make changes to the values in the motion supervision screen.
