Obj reference
Bobban
Hello !
I have just started to work with robotstudio, so i have a question about obj reference fault.
After i have saved the work, and maybe next day i will open it again, i will have a fault that
appears. Obj reference not set to an instance of an object? and i cant do anything? i need to start over
/Bobban
Hi,If you get this error message for all your stations, I recommend that you reinstall RobotStudio to see if that solves the problem. If you still have problem after the reinstall, please contact your local ABB office for support.Best regards,
ABB Robotics0
