Paint Power Pac and Conveyor Tracking [Painting PowerPac]
Has anyone had success with using the Paint Power Pac and Conveyor tracking?  Everytime I import and process a workpiece the system renames it and detaches it from the conveyor.  Then I am not able to re-attach the part to the conveyor because I get conveyor setup errors.
  • Hello,
    Try to first Process the workpiece to divide it and then attach to the Conveyor.
    Reason is that after processing a workpiece from Painting Powerpac, the part is divided and saved as a Graphic Component Group (GCG).
    Hope this helps,
    sudarshan
  • Thank you, that worked.  But I am still having a lot of problems with my part getting divided and then trying to use Auto Stroke.  I will start another thread with that problem.
