ArcWelding PowerPac 5.14.01 is released [ArcWelding PowerPac]
New Features
Creating Path from Geometry Edges and Save as Data File
Creating path from geometry edges and save the created path as path data file. The data
file can then be imported in PathView to create a weld.
Fixed Bugs
Obsolete weld instruction descriptions
Several Arc* instructions have added a ?_oTime?__ argument. Now they are also updated in
AWPP?_Ts instruction description files.
Exception after editing process templates
After opening a process template, edit, and click OK to finish, an exception may occur
