PC SDK bypass networkScanner process
Can I do an application in order to communicate with controllers directly?? via sockets, I mean if I do not use robnetscannhost process.
 Thank you in advance.
/Jordi.
  • Klaus
    Klaus ✭✭
    Yes you can. PC interface option is needed on the robot.
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Ok thanks,
    Do you know the robot's port numbre?? that the robot controller is listening.
    Thanks a lot.
    BR,
    /Jordi.
  • Hi
    The port and ip address is for you to decide:
    Basic examples
    Basic examples of the instruction
    SocketBind are illustrated below.
    Example 1
    VAR socketdev server_socket;
    SocketCreate server_socket;
    SocketBind server_socket, "192.168.0.1", 1025;
    A server socket is created and bound to port
    1025 on the controller network address
    192.168.0.1
    . The server socket can now be used in an SocketListen instruction to listen
    for incoming connections on this port and address.
    Regards
    Knud Erik Lindberg
    Danrobotics
  • do not use 5500-5599
    Some of them are used by robotscanner and rs  online. Can not remember witch but there is 1 TCP and 3 UDP port in that range
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
