Mirror
Thomas J
How do you mirror an entity or part thru VBA - API?
Thomas H. Johnston
PACs Application Engineer
Hello Thomas,
There is a function in RobotStudio called mirror (you find it in the Modify menu); one way to call it could be to run the following macro from RobotStudio (will not work to run from inside VBA).
Sub Mirror()
Dim tfmTransform As New Transform
tfmTransform.x = 2.5
tfmTransform.y = 2.5
Dim prtPart As Part
Set prtPart = ActiveStation.Parts.Add
Dim entBox As Entity
Set entBox = prtPart.CreateSolidBox(tfmTransform, 0.5, 0.5, 0.5)
ActiveStation.Selections.RemoveAll
ActiveStation.Selections.Add entBox
Application.RSE.CommandBars("Menu Bar").Controls("Modify").Controls("Mirror...").Execute
SendKeys "100{TAB}100{TAB}{TAB}1000{TAB}1000{TAB}{TAB}{TAB}{TAB}1000{ENTER}"
End Sub
Good luck!
/UlrikaUlrika Mor?n37952,56615740740
