Value property problem
Hi all,
The following code throws a generalException:
IRapidData iRD;
RapidData robTemp1;
robTemp1 = controller.Rapid.GetRapidData("T_ROB1","FORMATDEF1","myTest");
try
    iRD = robTemp1.Value;
catch (ABB.Robotics.GeneralException e)
From what I've been experimenting, it throws an exception only when "myTest" variable is too large.
This, when declared in FORMATDEF1.sys does not work:
Local PERS robtarget myTest{4,2}:=[[[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]],[[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]],[[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]],[[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]]];
but this works:
Local PERS robtarget myTest{3,2}:=[[[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]],[[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]],[[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],[[1731.77,-200,884.06],[2.69318E-05,-0.707507,0.706698,-0.00347952],[0,-1,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]]];
Using robTemp1.ReadItem(1,1) works fine (but I'm not supposed to know the dimension of my arrays @ runtime so i'm in trouble !!!)
And here is the content of the General Exception thrown:
Name      "ABB.Robotics.GeneralException"
IsHResultValid     true
HResult     -1073445865
ExtendedErrorInformation     "Get in ABB.Robotics.Dcl.Internal.CmdServer
<-- ReadCurrentValue in ABB.Robotics.Dcl.Rapid.RapidDataBrowser [Dcl.RapidDataBrowser] Error: reading the current value of the data '/{45C85090-7199-4D62-AFDA-1613140ADD26}/RAPID/T_ROB1/FORMATDEF1/pPckTable' failed.
<-- Read in ABB.Robotics.Controllers.RapidDomain.RapidData
<-- get_Value in ABB.Robotics.Controllers.RapidDomain.RapidData "     string
1- Does that mean we shall avoid using the Value property in RapidData ?
2- Should we start a post for advising some way of programming for developers to earn a bit of time and energy ?
Example
- Use methods within try catch blocks instead of properties for setting signals because in case of failure methods fire exception
- Use ReadItem and WriteItem because they always work
3- When will Dimensions property be available for ArrayData ? I saw them in debug in _rapidinfo.Dimensions but they are not yet accessible as properties
Best Regards
Antoine
