Urgent PC Interface option not found
joaopsf
Hi all.
I have developed a program in C# to interect between the computer and the controller. It all works very well in the simulation mode, but when I try to logon to the real controller using from the manual pc sdk:
ListViewItem item = this.listView1.SelectedItems[0];
if (item.Tag != null)
ControllerInfo controllerInfo = (ControllerInfo)item.Tag;
if (controllerInfo.Availability.ToString() == "Available")
if (this.controller != null)
this.controller.Logoff();
this.controller.Dispose();
this.controller = null;
this.controller = ControllerFactory.CreateFrom(controllerInfo);
------> this.controller.Logon(UserInfo.DefaultUser);
else
MessageBox.Show("Selected controller not available.");
I get the error showed above. I have no idea what to do. Can anybody help, it is urgent.
Thank you all in advance.
System.Exception was unhandled
Message=PC Interface option not found
Source=ABB.Robotics.Controllers
StackTrace:
at ABB.Robotics.Controllers.Controller.Logon(UserInfo user)
at ABB_Virtual_Test.KTH_ABB_IRB120Library.LogonController() in D:MyPhDProgrammingABB Virtual TestABB Virtual TestKTH_ABB_IRB120Library.cs:line 152
at ABB_Virtual_Test.Form1.button2_Click(Object sender, EventArgs e) in D:MyPhDProgrammingABB Virtual TestABB Virtual TestForm1.cs:line 335
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at ABB_Virtual_Test.Program.Main() in D:MyPhDProgrammingABB Virtual TestABB Virtual TestProgram.cs:line 18
at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
InnerException:
in you backup off the real controller you will find af file named system.xlm.Look for: <Option descr="616-1 PC Interface"/>If it's not there you have to contact your local ABB for new license keyBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Thank you for the help.I have checked and it is not there. So probably I have to talk with ABB.just one more question. I was using the service port, not the lan port, thus that make any difference, because I havenA?t been able to use the lan port and could not test.Thank you0
Just happy to helpYou can only use lan port if PC interface option is in the System.Serviceport is only to be used with RS online.Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
