PC SDK 5.14.01 Release
Release Notes
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Corrected Issues
Problem with Eventlog.MessageWritten event for Chinese language
There was
a problem with listening to the event Eventlog.MessageWritten on a controller
with Chinese language (culture code ?__zh?__).
RobotStudio installation removes 5.13 SDK files
When installing RobotStudio 5.14 on top of RobotStudio 5.13,  and choosing to remove RobotStudio 5.13 from
the computer, the 5.13 SDK files are not removed anymore.
ControllerFileSystemInfo.Exists
throws exception
You can
now use the property ControllerFileSystemInfo.Exists, when the ControllerFileSystemInfo
is initialized with an absolute path.
Limitations in UIInstructionEvent
You can
now specify a list view with up to 10 items from your RAPID program.  It is also possible to use the comma  character (?_o,?__) in the text for a messagebox.
Hint on creating a single installer for a stand alone PC SDK applicatoin
Creating a single
installer for a PC SDK application.
Niklas Skoglund2011-08-16 09:31:03
Best Regards, Niklas Skoglund
ABB Robotics
Developer Center
RobotStudio Blog
