Setup Similation
greatthb
Hi There,
My name is Tim and I am quite new with robotstudio. At the moment I am trying to follow the tutorial for the setup simulation. I have done all the SC as required, but I just wondering is the robot mechanism in the vedio. Is that mechanism can be sort of combine the tutorial of
Create Mechanism (3:54 min) and the tutorial of Station Signals and Event Manager (3:40 min). I really appreciate if somebody can help me out. Many thanks,
Tim
Hi Tim,The robot mechanism is a standard robot that comes with the RobotStudio installation. You will find all robot models under "ABB Library". The robot is controlled by a "Virtual Controller".I recommed that you go through the "Getting Started videos", before you start to use Smart Components.Best regards,
ABB Robotics0
