using program on a real robot
Nikita_N
Hey!
Answer please:)
How to use my program on a real robot (transfer and compile)???
Answer please:)
Hello NikitaThe easiest way is to save the program in RobotStudio Offline and load it in RobotStudio Online.If you also need the parameters, then you can create a backup in RobotStudio Offline and restore it in RobotStudio Online. You should be carefull with the motion parameter in MOC.cfg, because the real robot needs the correct parameters. You could first load the motion parameters of the real robot into the virtual robot (offline) and then you can work with the backup.Best regardsMarcel0
- 38 AppStudio
