Mechanism Transition Times
greatthb
I am sorry if this question sounds stupid!
I am trying to build a mechanism device. All the links and joints are well defined.
The only problem is the transition times seem not effected at all.
I am using the trail version, is that the reason. Can anyone tell me what I missed.
Thanks
Tim
Hi Tim,Transition times are only used when you run a simulation. But instead of using transition times, I recommend you to create a Smart Component to control your mechanism.The trial version has nothing to do with this, it has full functionality in 30 days.Best regards,
ABB Robotics0 -
HiI also had a mechanism that jumped from one position to the other. I also had the problem with Smart Components. Just when I made a video it took the correct transmission time. After some time also in normal play mode the transmission time was correct.Best regardsMarcel0
Hi Anders,It works perfect in SC and simulation.Thanks for your help,Tim0
