Error message [WebWare Server]
Question: What is wrong when i get this message?
edi wimwww/webware' for inclusion (include_path='') in Unknown on line 0
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
  • Hi Ronny
    When do you get this error???
    Per Svensson
    Company Specialist
    ABB Automation Technology Products
  • I get the error when trying to connect to the server.(From my laptop)
    Punching in the ip +/webware, this message is the only thing that happens.
  • Hello Ronny,
    It appears that you are trying to access your WWServer using a UNC path. It is necessary to access it using a url. If WebWare Server was installed using the default configuration, it is a set up as a virtual directory and can be accessed by entering:
    http://<serverIPaddress>/webware
    You may substitute the server host name if it is resolvable by your PC, but theIP address should always work.
    RussD37957,6834490741
    Russell Drown
