error 37001 hardware
A? A?sir,
I have a problem in robot IRB 2400 S4 Display is showing this message--------
Motor on contractor did not activate /energize or KM3 supervisory contractor is not activated/ energized or motor on signal is not distributed through auxiliary contact.
what should I do please send solution as soon as possible.
we have checked
1 power supply 400/410 is coming
2 contactors are ok
3 KM3 supervisiory contactor has changed
we have checked
2 contactors are ok
I Have checked auxiliary are ok0
ankit gupta said:I Have checked auxiliary are okPlease, can you give me the diagram about contactors that you guys are talking.
I have searched them but can't get the result0
