Installation of FlexPendant SDK with VS2005
I follow the procedure to install the Flexpendant SDK. I first inatall the virtual studio 2005, then robot studio vs5.14.01.01. But when I want to create a new project I can't select any Flexpendant application.
Any idea?
Installation procedure The installation procedure is very simple. By default FlexPendant SDK is installed when you install RobotStudio. For more information, see Installing RobotStudio, in Operating Manual - Getting started, IRC5 and RobotStudio.An installation wizard will guide you through the installation. If you would like to install RobotStudio without installing FlexPendant SDK, or remove FlexPendant SDK from RobotStudio select Custom in the RobotStudio installation wizard and select or unselect the feature FlexPendant SDK.
  • I install robot application builder for robot studio 5.10 and then it was ok.
