Error [MachineTending PowerPac]
Hi, I'm Alvin. I faced a problem for starting Machine Tending PowerPac.
Machine tending Unable to generate a temporary class (result=1).
error CS1705: Assembly 'ABB.Robotics.MachineTendingPP, Version=5.14.1394.1032, Culture=neutral, PublicKeyToken=null' uses 'ABB.Robotics.Controllers, Version=5.14.1032.0, Culture=neutral, PublicKeyToken=1da709b7d1f14b7b' which has a higher version than referenced assembly 'ABB.Robotics.Controllers, Version=5.14.204.0, Culture=neutral, PublicKeyToken=1da709b7d1f14b7b'
2011/9/9 ?,<?_^ 01:42:13 Machine tending</strong>
And then
MachineTending: Internal error
How can I deal with.
THX
Use the machinery developed earlier in this example to compute the
order of the image of this homomorphism.
> GroupOrder( HomImage( hom ) );
zainsalaar2012-05-15 13:45:190
