Editor unresponsive at 30 sec intervals: Windows 7
I'm using RobotStudio 5.14 in Windows 7.
I'm connected to the service port of a real controller via the crossover cable.
At roughly 30 second intervals, the editor is unresponsive. I am unable to type, move the cursor, etc. This lasts for roughly seven seconds.
This is such a drain on my productivity that I copy the code to a third party editor, make my changes, and paste the revised code back into RobotStudio.
My guess is that RobotStudio is locking out the editor while it synchronizes with the controller.
Is there some way to eliminate this behavior, so that I can edit continually?
Thanks for your help.
GregoryAshmore2011-09-19 16:23:35
Gregory Ashmore
Xigent Automation Systems
  • Hi Gregory,
    If you not have installed RS 5.14.01 with SP1, please do that, it will probably solve your problem.
    ABB Robotics
  • I have installed 5.14.01 with SP1. The controller I was working on is at a customer site. It will be several days before I can connect to another controller here at our shop. I'll let you know if it works.
    Thanks.
    Gregory Ashmore
  • I face them same problem after reply changes in editor.
    Some times RS hangs for long time.
    Yesterday i had a meeting with another RS user here in denmark and he has the same problem.
    After release of 5.14.01 it got mutch better but not perfekt.
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
