Adding a UserControl
in ScreenMaker
Is it possible to add UserControls to ScreenMaker ? I created a simple UserControl (Just a button that shows a text when pressed) for a quick test and added the reference to my ".dll" in the advanced settings of the project properties. However my control is not shown in the Toolbox. I would have expected it to be in the third party control section. Has someone tried this before ? Does it work ?
Hello,As i understand the requirement is to add a user control in ScreenMaker Toolbox.You could refer to a similar post provided in the link below, it will give you some inputs:Adding .NET dll can in advanced settings of the project properties would help to call the .NET methods from ScreenMaker defined in the dll. This will not make the control appear in the ToolBox.Thanks0
- 40 AppStudio
