FlexPendant IO configuration
Hello all,
in my FlexPendant app I'm using virtual signals to communicate with the RAPID code. On startup there is a check if these signals are avaiable. But is there a way to create those signals from the app if they are not existing?
I've found the Configuration.Write() method and I can change signal parameters like signal type using this method, but I cannot add a new signal...
Regards
Matthias
