Possible bug in 5.14.01 SP1
cabraja
Virtual Flexpendant.exe process doesnt end when closing the pendant window.
It stays running in background wich makes it impossible to show
the flexpendant again if needed.
The process needs to be killed to be able to start it again.
Anyone else have this issue?
Windows 7 Pro 64-bit
very old bug that never has been fixed. just kill FP process ind taskmanager end you can restart FP again.Hopefully it will bee fixed some day but have stoped thinking about it. It's just a happed to kill it
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
i dont understand well your answer can you explain more please.....i am new in robotstudio
John 3.160 -
Thank you for the reply Klaus.I figured out how to kill the process manually but i was not sureif it was a user or software error.I'm new in RobotStudio and only had a 5-day course onhow to use it ect.I did not have this issue in 5.13 version that i used before 5.14.Same computer was used and i did a clean install of 5.14tia Antonio0
hi djhosoer.Sometime when you close the virtual Flexpendent(FP) it does not close the procces completly and dispose all. When that happens you can not open the FP again before closing the process in the task manager.but if you do not have any problems with reopening FP then no worry
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
