reading e-stop signal
Hi All,
I've got a quick question which i'm hoping you knowledgable people may be able to help with.
I need to send a signal to a PLC whenever any e-stop has been triggered (ES, AS, GS).
The signal will be used to open a door which is controlled via a PLC.
Thanks
Hi,For ES you can use the "System Output" signal "Emergency Stop".In the "System Parameters Reference Manual" (which you will find under the help button in RobotStudio) go to Topic I/O - Type System Output - Status values - Emergency Stop, for more information.Best regards,
ABB Robotics0 -
Thank you very much for that.
I've got that bit working now.Another question, is there a way to run a rapid code if an e-stop has been triggered e.g.when estop is triggered, run rapid code to set some flags?Many thanks0 -
HiYou could create a event routine that will be executed with the event QSTOP and check in there if the emergency system output is set.You could also do a crossconnection with the ermergency system output in the EIO.cfg parameter.You could also use multitasking to check the ermergency system output.Best regardsMarcel0
Thanks everyone,I ended up using the QSTOP with an event routine. Works like a charm.Thanks again.0
