Position failure
Fatih
Hi i'm new in this RobotStudio.
I've a SmartComponent which makes a copy [Source] of an object. Properties of Source: When I type a number (ex. 100mm) in Position (x,y,z) and then execute the signal then the object is created but far far away from it's position.
I've also installed SP1 from www.robotstudio.com but still not working.
Did anyone have this problem?
Best Regards
Fatih
Best Regards
Fatih
HiCould it be that you gave in 100 meter? A lot of values are in meter and not in mm.Best regardsMarcel0
Hi Marcel. The offset in the Source proberties was in mm. I tested a pack&go from Fatih and faced the sam problem. 1 mm offset result in 10000 mm offset but zero mm offset worked.I also see the local origon and it was okay. i think it's a bugBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
