RapidDatabinding source "FP SDK 5.14"
Hello. I am to developing an aplication in c# to make some changes to rapid data more faster.
My problem is that i already have many modules, that basicly are the same program , but have diferent data values, so when i drag rapiddatabindingsource to designer,  i need to enter task, module and, variable names, but since i want my application to work with all the other modules this doesnA't work. All the other modules have the same task and variable names.
Any ideas?? Thanks...
  • Hi hydron,
    Could you do some screenshots to describe the problem, or some code?
    IF I understand your problem, couldn't you have a list with all the different modules, like this, so the user selects the module to work with, then whenever that is changed change the rapiddatabinder to accomodate?
  • Thank you very much.
    I think that should do, Ill try code
  • Hi
    Regarding your other questions.
    First go through the FlexPendant SDK Application manual chapter:
    "Using the FlexPendant SDK - Using the Controller API - Accessing the controller", there you will find the code examples you need.
    Also when it comes to the databinding, remember to utilize the
    SuspendBinding/ResumeBinding
    when the user switches focus and/or modules.
  • Ok.
    Thank you very mutch, I was able to make it work with this code.
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    Dim TaskName As String = "T_ROB1"
    Dim modulantal As Integer = robotController1.Rapid.GetTask(TaskName).GetModules.Length
    ComboBox1.Items.Clear()
    For i = 0 To modulantal - 1
    Dim modul As RapidDomain.Module = robotController1.Rapid.GetTask(TaskName).GetModules(i)
    ComboBox1.Items.Add(modul.Name)
    Next
    ComboBox1.SelectedIndex = 0
    End Sub
    Private Sub ComboBox1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ComboBox1.SelectedIndexChanged
    TextBox1.Text = ComboBox1.Text
    End Sub
    Now i need a code or an example to add a checkbox and with that checkbox change the value of a boolean variable from true to false.
    That variable is stored on the module that i choose from the combobox (ComboBox1.Text)
    Best regards
