Arrays Rank and dimensions
I know the question has already been placed by Antoine but without any answer.
When a rapiddata returns IsArray, is there a way to know the rank and size of each dimensions.
there is a not too dirty solution with try/catch to get the number of dimensions (copied hereunder) but I do not see an acceptable workaround for the sizes.
As this information is available under the debug window via the dimensions int[] it should be possible to reach it from the application.
Any help warmly welcomed.
BR
Laurent
Note: Code to find an array number of dimensions
static int NbDim(RapidData d)
               string s;
               try
                    s=d.ReadItem(1).ToString();
                    return 1;
               catch
                    try
                         s=d.ReadItem(1,1).ToString();
                         return 2;
                    catch
                         try
                              s=d.ReadItem(1,1,1).ToString();
                              return 3;
                         catch
                              try
                                   s=d.ReadItem(1,1,1,1).ToString();
                                   return 4;
                              catch
                                   return -1;
