some problems about "Module"
doc-zee
i use c# to program and i had met something problem .when i click "1.mod",the robot in vs moved just like i want ,but when i click "2.mod",the robot didn`t move. And then i check the virtual flexpandent,it says like the picture below(i have reset the pp,and i release the mastership):
Event MessageError in T_ROB1-Line6DescriptionGlobal routine name main ambiguous.Data for this message is not saved in any robot controller event log.If acknowledged the message will be removed.ActionsGlobal routine must have names that are unique among all the global types,data,global routines and modules in the entire program .Rename the routine or change the conflicting name.0
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 35 AppStudio
