how to use "SocketReceive" to receive 3 "num"
doc-zee
now i want to use socketmessage domain to receive the 3 data one time from pc.but i don`t know how to receive.Is there any instruction like c#"string.split()"?If anybody know how to solve it,please tell me !
you must to receive the 3 data with the instructionSocketReceive "Your socket" Str := "the string where you want to save the 3 datas";now, you can process this string to separate the 3 datas.I hope that helps you0
thanks a lot,i`ve solved the problem!0
