External Axis Wizard - Add-In
Hej,
I've installed the add-in External Axis Wizard.
In my RS Add-in Tab I found the External Axis Wizard in the general tree... I've clicked with right button and loaded the add-in.
But and now ?
How that add-in is proposal to use ? Do you have any manual ?
After load the add-in, where can I "try to use" in the RS ?
Thank you in advanced,
Marcus Daniel
Marcus Daniel
ABB Robotics
mobile: +55 11 8586-4960
  • Hi
    I had the same problem and a colleague from ABB helped me.
    You can find the External Axis Wizard under: Home, Robot System.
    Best regards
    Marcel
  • Thank you Marcel !!! Now I found ...
    Great!   Smile
    Marcus Daniel
    ABB Robotics
