No Restore for real Robot Cell
After creating a new Robot with a real Key-String, Restore is not possible.
CASE1:
Operatin Mode <250mm , no Paraeters are loaded in Virtual Robot Browser.
After entering the Programmers Code in Restore Menue, the TeachPendant shows Error 12033. Error restoring configuration parameters (MMC.cfg) ????
Case2:
Operatin Mode <250mm , all Paraeters are loaded in Virtual Robot Browser.
I can go on the TeachPendant to Restore Menue, select Source directory press Ok and nothing hapens, no Programmers Code, nothing.!!
How the Hell can I create a real existing Robot Cell???
  • Hello Horn,
    Welcome to the SoftWare Support Forum!
    From what we can see you are doing everything right.Could you please upload your backup and your Key-String so we can test it?! What version of QuickTeach are you using?
    Thank you in advance!
    Best regards
    /Ulrika Mor?n
    Support Engineer
    Ulrika Mor?n37964,4315046296
  • Hello Ulrika Mor?n,
    I would upload you my backup+Key with pleasure...
    but how??
    With friendly regards
    T. Horn / Programmer
  • Hello again,
    If you zip your backup and use the button at the very right in the "Post Reply" field you should be able to upload things.
    Best regards
    /Ulrika Mor?n
    Support Engineer
