Changing system.
Makoriko
Hey,
I've got this robotstudio project in our course, where i have 3 robots in my system. Layout is done and coding is going pretty well, but I now need to change one robot to other model. I'm pretty lost about how to do it, because the system is allready setup and I cant find a decent way to do it.
Do I need to setup up system again from new layout where the new robot model is or can robot be changed in a system that is already build up?
I'm just afraid I need to write majority of the code again etc..
-once i thought i was wrong but i was mistaken-
Hi,I recommend you to save the programs , create a new system which you add to your station and then load your program into the new system.It is possible to modify the existing system with System Builder but as an I-start would be required all programs would be removed anyway.Best regards,
Anders Jahnberg
ABB Robotics0 -
Hey,I did like you recommended and it worked out just fine!Thank you AndersJ for help
-once i thought i was wrong but i was mistaken-0
