No way to display real value inside numericUpDown?
Here is what I wanna do :
- read a rapid data from a num. eg : 45.5
- display it on a numeric Up&Down control
When the action to read the rapid data is done, the numeric UpDown control display : 455 (the value without decimal dot). I tried the same thing with an application variables type dnum but the result is the same.
Can someone help?
Can someone help?
Norberg Thibaud
Wow Company s.a.
Belgium
Wow Company s.a.
Belgium
Hello Norberg,Could you tell which version of RobotWare you are using and the PC/FlexPendant language settings being used.Are the results that has been described in your post on Virtual FlexPendant or Real FlexPendant.Thanks,Abhishek0
Its better to mention that which robotware you are using to make it form
