Independent move axis 6
AlexK
Hi, having issues with independent axis on axis 6. We're getting a Duty Factor warning. Says something about adjustments in the error message to "reduce damage to motor and gearbox.Is it a heat issue or is it a wear of the gearbox issue, and what would be adjusted?
We're grinding round items with the robot so the independent axis movement is requiered.
Thank you for your help
/Alexander
Best regards
Alexander Källberg
Alexander Källberg
- 858 RAPID Programming
