Remote connection for many robots
Gomez
In RS-help it is described how to set a firewall for remote network connection for one robot.
How can I remotely connect to two (or more) different robots (obviously with different private IP addresses) in the same factory-lan, at the same public IP?
...usually it is not possible to port-forwarding the same ports for different lan IPs.
I am waiting for the robots and I want to be sure of their settings.
Thanks in advance
BR
Thanks in advance
BR
Take a look at www.westermo.com under the handbook menu. There they show how to make certain applications. Have used there products for example a dialup connection which gives access to 2 robots a PLC and a PickMaster PC.Per Svensson
Consat Engineering0
