Database [WebWare Server]
Thanks for the help so far,with my previous problems.
A new one comes here:
Can i export the datas that i create in my report manager?
Is it possible to export them over to MS Exel for example? I want to make different kinds of diagrams etc..
Ronny
  • Hello Ronny,
    Probably the simplest method would be as follows (this applies to a data table):
    1. Display the desired report with the WebWare client.
    2. Select all of the data in the table and do a "ctrl+C", i.e. copy.
    3. Paste this data into a Word document, save the page as html.
    4. Open Excel, select Data>Import Data then browse to the html file.
    5. Follow the steps for importing data and format as necessary.
    I did this in Office 2003, I expect Office 2000 and later should work similarly.
    Russell Drown
