RobotStudio .NET exception
Trying to build a station by going Online then clicking the Go Offline button.
RS asks me to load a library for the Conveyor which I do, then I get this;
So I click Yes then after a few seconds I get the following error;
RobotStudio .NET exception: Exception from HRESULT: 0xC0048416
Base exception: COMException
   at Interop.LgVCHelper.ILgVCHelper.SetSignalLogicalState(String signal, Boolean blocked)
   at RobotStudio.Services.Controller.VcManager.GetConveyorParameters(RsIrc5Controller irc5Ctrl, RsIrc5ConveyorEncoderUnit encoder, Boolean& reinitSubscription)
   at RobotStudio.Services.Controller.VcManager.UpdateConveyorParameters(RsIrc5Controller irc5Ctrl)
   at ABBInternal.Controller.StationVCManager.PostRestartHandling(LibraryLoadLogic libraryLoadLogic, RsIrc5Controller irc5Controller, Mechanism[] mechanismToMap, Boolean bCheckBaseFrame, Station station, Boolean& advancedStartup, Boolean& restarted)
and
BT0905472-10_8: Disconnected    05/03/2012 13:16:44    Controllers
After that station does not work.....
Any Ideas?
Cheers.
  • We need to look closer at your backup to figure out what's going on. Please get in touch with your local ABB Robotics Service representative that can forward your issue to our tech support.
    ABB
