CompactFrameWork error
Klaus
I have a FP sdk project that is made with RAB 5.10.
After upgrading to VS 2008 and RAB 5.14 i cant open my views in designer.
I get 8 different errors but think it's the same problem.
Error is:
The type 'Microsoft.CompactFramework.Design.UnsafeUserControl' has no proberty named 'Fontname'
it's the same with the proberties TextAlign,HorizontalAlign, LineStyle, VerticalAlign and is in all my controls.
Exampel:
Me.LB_SaveRcp.FontName = New ABB.Robotics.Tps.Windows.Forms.DesignerFont("Font10")
Can anyone help PLZ
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Maybe it is related to this: http://social.msdn.microsoft.com/forums/en-US/vssmartdevicesvbcs/thread/f7c3ce23-d04d-45a8-8b27-920d15f41aad/I have no experience with this problem, so the above link was a wild guess.0
Hi Niklas.But that i don't understnd is that it worked in vs2005 with rw 5.10 and nothing has changed. the FP needs now to run on af new controller running rw 5.14Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
I give up.
I have made a new Project with the 7 forms and then copy All code from ny old Project to the new Project And used last evening A3n that
Sad to say but my last Project with FP interface.
To much trobles with it if the costumer want,s to opgrade rw after. This Project i was only going to change some screen txt and run it A3n an new controllerBest Regards
Klaus Soenderhegn
Hi Klaus,sad to hear that it was the last app. But I understand your frustration.If there is something we can do to make you change your mind, we will try to do it.I recommend that you contact our developer support team.Just one question, have you upgraded the references to the FlexPendant assemblies in your project from whatever version it was before, to the 5.14 version of them?0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
