Fp interface on rw 5.14
How Can i write a Fp interface to rw 5.14?
As i Can se i must use rab 5.14 but Then i must use vs 2010. Another tropic tells that it Can not use compact frameworks in vs2010 . Will a rab 5.13 run under rw 5.14? I have very bad expeeience with differentiere rab and rw versions on the same controller
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus,
    To develop a FlexPendant interface for RobotWare 5.14, you should use VisualStudio 2008 and FlexPendant SDK 5.14.
    It is correct that  2010 does not support Compact Framework.
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
