exception during starting Station
have a problem with one station: a second after the message that the station was successfully loaded, an exception emerges "value cannot be null. Parameter name: source".
does anybody know about this problem and eventually has a solution?
the station is using RobotWare5.11.1033 - all my other stations base on different RWs and are working just fine - so this may be a problem with this RW?
am using RS 5.14.4241.204
thanks
Please create a support log by following the instruction in http://forums.robotstudio.com/forum_posts.asp?TID=2164 and upload it here.Henrik Berlin
ABB0 -
thanks, here the report: webwiz/998/RobotStudioReport_2012-0326_151634.zip0
Thanks for providing the log files. It seems as if there is a problem with a joint target. The error occurs when a path containing a joint target is drawn in the graphics viewer.Are you able to do anything, or does the exception prevent you completely from working with the station? If you can do something, try verifying the joint targets. Or make paths with joint targets invisible.Henrik Berlin
ABB0
