I/Ocross connection from VC to SC
How do you get a cross connection between a VC and a Smart component?
I.E from doGripper in the VC to diGrip in the SC
Many thanks
  • You can create cross connetions using Station Logic.
    ABB
  • Thanks... simple when you know !Wink
  • Very useful thanks, but I need send signal between the VC and smartcomponent in both direction.
    Now i canA't connect an output of smart component(like executed) to and a my signals in the VC, only let me connect to an Local signal like AS1, EN1...... I tried to crate a new unit in local bus , but i dosenA't work.
    Can you help me!!
    Thanks in advance
  • You need to define your own I/O-signals in the controller. Create a new unit of the type "Virtual" that you connect to the bus "Virtual1". On this unit you can define your signals. For more information take a look in the System Parameters Reference manual.
    ABB Robotics
