FlexPedant SDK Problem with load XML File
i try to open and read an XML-File from the hardrive. This Folder is the system-home directory. but unfortunatly it is not working. the program detect an error.
that is my programcode:
XmlDocument Doc = new XmlDocument();
            try
                if (FileSys.Exists(FilePath))
                    Doc.Load(FilePath);      //here is the fould!
the string FilePath is ok. the reason why the system chrashs i do not know.
does anybody know what the mistake is?
thanks for the help. Clap
sorry. i have forgotten a importen thing. the complete programm is runing under a virtuel system. on a real robot the program have this fould.
programming with.
framework 2.0
tested with virtuel system 5.13. Ok!
tested with a real system 5.14. Not Ok!
Paulaner2012-03-24 20:48:00
  • Check if the XML is being used by anyother process..
    or
    catch the exception and see the exception message.you could get more details about the flaw.
    good luckSmile
    Sandeep
