Question
Greetings allA?
I am new to robot ware 5.12.04 and I have a little problem I wish to create a path along the edge's of a gas tank (witch twists and is very uneven), i tried to use "create target on edge" but im finding that some of my points are in mid air and not were they were suppose to be, am I using it wrong or do I have to manually correct every missed point?A?
When searching the forums I came across a command "path from curve" is this command still in the program or is there an alternative?
Any help would be much appreciatedA?
Ole
  • Hi Ole,
    I recommend that you install the latest version of RobotStudio (5.14.02.01) and use the function "AutoPath" which is the successor to "Path from Curve".
    ABB Robotics
