write robtarget
I'm trying to change a position of a robtarget from PC SDK
for starters, I followed some code I found in the forum for writing a robtarget with the values of the current position. It is as follows:
Dim CurrPos As RobTarget
CurrPos = Controller.MotionSystem.ActiveMechanicalUnit.GetPosition(CoordinateSystemType.World)
Dim MiRobtarget As New RobTarget
Dim MiRapidData As RapidData = Controller.Rapid.GetRapidData("T_ROB1", "modRobotStudio", "pTest")
MiRobtarget = DirectCast(MiRapidData.Value, RobTarget)
MiRobtarget = CurrPos
Using master = Mastership.Request(Controller.Rapid)
Try
MiRapidData.Value = MiRobtarget 'Here I get the error
Catch ex As Exception
MessageBox.Show(ex.Message)
Finally
End Try
End Using
When trying to write the rapiddata.value, it gives me an error:
"An argument specified by the client is not valid for this type of operation."
Could anyone help me? What I'm doing wrong?
thank you
Hi londoneye,Your using master looks a bit funny since I see no "as Mastership" in it. But that is not your issue.Instead if you look in the PC SDK application manual, [Using the PC SDK - Rapid domain - Working with RAPID data] you can see this:[quote]TheRapidData object stores the path to the RAPID data. But this is not enough if you want to access its value (at least not if you want to modify it). To do that you need to create another object, which represents the value of the RAPID data.
In the RapidDomain namespace there are types representing the different RAPID data types. To create the object needed to represent the RAPID data value you use the RapidData property Value and cast it to the corresponding type, for example Num, Boolor Tooldata. [/quote]Your MiRapidData is still just a generic cast of rapiddata, which can not really be modified in the way you do. (Two different types).So you need to set your miRobTarget to your miRapidData and then change the miRobTarget.But note that this only changes the value in the controller memory, it does not change the text in the progrom module.Here is a code snippet that I ran in RobotStudio (hence the logger stuff, change it to something that works in the environment you use).ctrl.Logon(UserInfo.DefaultUser)
Logger.AddMessage(New LogMessage("log on"))
Using m As Mastership = Mastership.Request(ctrl.Rapid) 'changed as mastership
'directcast the rapid data - should have a detection+try catch if its not there
Dim rd As ABB.Robotics.Controllers.RapidDomain.RapidData = ctrl.Rapid.GetRapidData("T_ROB1", "Module1", "Target_10")
'declare a variable of the data type
Dim rapidRobTarget As ABB.Robotics.Controllers.RapidDomain.RobTarget
'test that the data type is correct before cast
If TypeOf rd.Value Is ABB.Robotics.Controllers.RapidDomain.RobTarget Then
Try
rapidRobTarget =DirectCast(rd.Value, ABB.Robotics.Controllers.RapidDomain.RobTarget)
'change stuff
Logger.AddMessage(New LogMessage("before - " + rapidRobTarget.ToString()))
rapidRobTarget.FillFromString2(ctrl.MotionSystem.ActiveMechanicalUnit.GetPosition(CoordinateSystemType.World).ToString)
Logger.AddMessage(New LogMessage("after - " + rapidRobTarget.ToString()))
Logger.AddMessage(New LogMessage(ex.Message))
End Try
End If
End Using
ctrl.Logoff()John
Developer Center0
