PCSDK app freezes
Hello!
When I start my application (C#), app freezes and meanwhile RS does nothing. Output is silent and flexpendant shows no change in mastership.
However, if I alt+tab to VisualStudio - it unfreezes and does it's thing (until I alt+tab back).
I can make it work in visualstudio debug mode, by stepping over each line of code manually. If I do that - robot moves and does everything by the code.
Maybe it's common issue and you can help me solve it?
John Wiberg2012-04-26 14:35:37
Nope, I don't recognize this behavior.A guess would be a GUI threading problem? Maybe updating graphics in event threads?Check out the PC SDK application.[Developing Controller applications] > [Controller events and threads]You could also test by not using the VS debugger, starting the app with [Ctrl]+[F5] instead of just [F5].John
Developer Center0 -
Thanks for reply, but I fixed it on my own. Solution is simple - don't run VS+RS on virtual machine. It does not work well together.
- 37 AppStudio
