Transferring Targets to New Workobject
DLcygnet
I created a rather extensive path in the work object for one robot. Then I mirrored the path and would like to transfer that path to the second robot. In 3.2 all I had to do was drag the relevant points to the new workobject, but it's seemingly not possible in 5.06. The manual mentions that it is possible on page 146 but gives no further directions on the actual process. Help!
Lisa Cardon
Saving the world from the scum of the universe.
Hi Lisa,
If you click on the More button in the Mirror Path Window can you select the Receiving Robot for the mirrored path. You can also select in what workobject the mirrored targets should be created.
ABB Robotics0
This discussion has been closed.
