a delay time before robot moving
hello, everyone
recently, I got a problem, it's a big trouble for me.
The robot always run repeat at one position except for changed the offset from pc-sdk.
But when i changed the offset ,there is a delay time about 0.5s before robot moving.
Dose anyone find this problem ?
  • how are you changing the offset?  RAPID Data domain or Messaging domain or ???  I found recently that removing Messaging from my application significantly improved performance.
  • I use the RAPID Data domain.
    Excuse me , what do you mean about removing Messaging?
    Could you tell me how you change the offset?
    thanks
  • Hi,
    has anyone figured this out?
    I also get a  0,5 s delay.
