PC SDK 5.14.02 Userdefined crash
labu
Hi all,
We have a PC SDK App which used to worrk fine dealing with fairly sophysticated RECORDS.
While upgrading to 5.14.02, where it is said in the release notes that some changes where made at init of UserDefined for better initialisation, everything turns weird...
_data = new UserDefined(DataType) does not generate any components and any attempt to reach components makes a System.Exception...
The same for the DataType.GetComponents().
I am running under VS2010 in Framework 4.0 (mandatory for vision app and performance)
I have to add that any RapidData pointing to a record returns a System.Exception when trying to access Value.
It seems to me that any user record which includes records (standard or user) fails to initialise.
Looking at the stack clearly shows it's relative to the added initialisation
A? ABB.Robotics.Controllers.RapidDomain.UserDefined.GetComponentsAndAppendDefaultValue(RapidDataType objRapidDataType, String& fillData)
A? ABB.Robotics.Controllers.RapidDomain.UserDefined.get_Components()
A? Test40.Form1.button1_Click(Object sender, EventArgs e)
A? System.Windows.Forms.Control.OnClick(EventArgs e)
A? System.Windows.Forms.Button.OnClick(EventArgs e)
A? System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
A? System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
A? System.Windows.Forms.Control.WndProc(Message& m)
A? System.Windows.Forms.ButtonBase.WndProc(Message& m)
A? System.Windows.Forms.Button.WndProc(Message& m)
A? System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
A? System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
A? System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
A? System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
A? System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
A? System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
A? System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
A? System.Windows.Forms.Application.Run(Form mainForm)
A? Test40.Program.Main()
A? System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
A? System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
A? Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
A? System.Threading.ThreadHelper.ThreadStart_Context(Object state)
A? System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
A? System.Threading.ThreadHelper.ThreadStart()
SAMPLE DATA FOR ANALYSIS
RECORD gripperconf
num headsdown;
num headsvac;
num headsblow;
num toolnumber;
num prodspercycle;
ENDRECORD
RECORD ppspointdata
string name;
gripperconf conftool;
speeddata h_speed;
ENDRECORD
RECORD toto
string name;
num val;
ENDRECORD
RECORD tata
string str;
speeddata sd;
ENDRECORD
TASK PERS toto montoto:=["toto",12];
TASK PERS tata matata:=["tata",[1,2,3,4]];
The only data workabe is montoto of toto type (only atomics)
URGENT FIX NEEDED AS IT IS A MAJOR REGRESSION
without any easy workaround
RECORD gripperconf
num headsdown;
num headsvac;
num headsblow;
num toolnumber;
num prodspercycle;
ENDRECORD
RECORD ppspointdata
string name;
speeddata h_speed;
ENDRECORD
RECORD toto
string name;
num val;
ENDRECORD
RECORD tata
string str;
speeddata sd;
ENDRECORD
Still buggy on 5.14.03
Hi labu,This has been dispatched to R&D.For testing purposes, from which version did you upgrade?Have you run this on 5.14.01? (Since you say the changed behavior was in 5.14.02).John
Developer Center0 -
Hi,Yes it is ok in 5.14.01.On another hand, I am wondering why should a Userdefined be initialised with default values wheres it is a safe way to make sure your data has relevant info in if items are non null.What is the goal behind this default init?I feel it should be optionnal as this might compromise older apps relying on != null to make sure the data is valid.0
Hi labu,R&D has looked into it and there is an issue with the update just like you have observed.There will be a fix for that in the next release.Right now we are looking into if there are any workarounds. We have some interesting leads with how and when the RAPID is declared, which can prevent the behavior. As soon as we have tested further I'll give you an update.John
Developer Center0 -
Hi John,
We are currently still blocked with 5.14.01 and new robots are delivered in 5.15
Has this issue been fixed?
Hi John,
Could you please confirm that the issue is fixed as we have got the same problem with PC SDK 5.15 connected to a robot in 5.14.01
