Smar Tac Sensing with Gas Cup/Nozzle possible??? [ArcWelding PowerPac]
Dear All,
           Following are the details of the Robotic ARC Welding System Products:-
1. ABB IRB1600ID ROBOT WITH IRC-5
CONTROLLER.
2. ESAB WELDING POWER SOURCE Mig 5000i, ESAB Wire
Feeder Aristo 3004W
3. Binzel ABIROB-A500 Welding Gun
4. CO2 GAS 100%
5. Welding Wire CuCr 1.2mm
6.Material Specification:- MS with redoxide coating
, 5mm thick.
     Currently we are using the welding wire for smar tac searching. It is working OK. But, due to the problems in the component, Viz. Non-uniform coating of Redixide on the sensing surface, we are not getting the repeatability in search results.
     For avoiding this we are trying to use the Gas Cup/Nozzle for sensing the component.
For that what changes do we have to do in the existing system hardware???
Vishal,
vishalpatil3.82@gmail.com OR
vishal.patil@electronicagroup.com
