RobotStudio .NET exception:
Hallo
I get the following error message wehm i start the station:
RobotStudio .NET exception: Der angegebene Pfad und/oder Dateiname ist zu lang. Der vollstA?ndig qualifizierte Dateiname muss kA?rzer als 260 Zeichen und der Pfadname kA?rzer als 248 Zeichen sein.
Base exception: PathTooLongException
   bei System.ComponentModel.ReflectPropertyDescriptor.SetValue(Object component, Object value)
   bei System.Windows.Forms.RadioButton.PerformAutoUpdates(Boolean tabbedInto)
   bei System.Windows.Forms.RadioButton.set_Checked(Boolean value)
   bei ABBInternal.StationManagement.LibraryManager.LibraryManager.Project_ActiveProjectChanged(Object sender, EventArgs e)
   bei System.EventHandler.Invoke(Object sender, EventArgs e)
   bei ABB.Robotics.RobotStudio.Project.set_ActiveProject(Project value)
Does anyone know a solution to this problem?
Thank you very much
regards philippe
  • Try shortening the name of the station.
    ABB
  • [QUOTE=Henrik Berlin]
    Try shortening the name of the station.[/QUOTE]
    i got following error too :(
  • Is it a Pack&Go you are trying to open? In that case, open it in a folder with a short search path, such as c: emp and see if that helps.
    ABB
  • Hello friends
    Thank you for your support.
    My problem was that I'm using Windows 7 Offline files. I have included a folder in the Documents tab. When I was offline then the path is too long. RobotStudio has indicated assign a temporary name that had caused the problem. After delete the reference folder, the problem was fixed.
    Best Regards
    philippe
    regards philippe
