UAS settings
scott24
We use the UAS settings. That means that by us, the default user has few rights on the robot. After the the loading of our UAS configuration, it is no more possible to load a new system with robot studio online to the bootserver. (with Ethernet)
Is there a solution to change the user used by "robot studio online system builder" by building the connection with the bootserver?
Is there a solution to erase the UAS settings of the robot and come back to the factory UAS settings?
Thanks a lot!
HiConnect the controller with HyperTerm and write "uas_disable"Best RegardsSinan AYDIN / ROBOTMER0
'uas_disable'... is tempory until the controller is restarted !0
