Error While creating New System
Hi guys,
I am facing problem when I try to create a new system with IRB6600, IRB6620
When I create a new system from Template, It is working fine, means no error msgs.
But When I create a new system using System Builder the same configuration of Template system. It is prompting the following msgs
When I am using the system in the station, [the manipulator selected from the ABB Library-Robots], I am getting error in the output box. "Could not change motor state".
Kindly give me the solution.
Lingaa
  • Jorge
    Jorge ✭✭
    [QUOTE=Lin]Hi guys,
    [/QUOTE]
    is the external axis correctly defined in the parameters? (Mechanical Unit Gropu, Task, etc).
    /Jorge
    Jorge Turiel
  • You need to select a drive module configuration that matches your robot, see below (use Drive System 09 ...)
    ABB
